Compression Results ?
Old Dec 18, 2011 | 09:42 PM
Hylander7's Avatar
Hylander7
Default Compression Results ?
Post #1
So I did a compression test on my truck today.
Seems odd that one whole bank is perfect and the other not so much, especially cyl. #2
What do you think of #2, the book says to be within 80% of highest cyl. and it is, but not by much.
All spark plugs look near perfect, Test was done with cold engine.
1= 142
3= 143
5= 143
7= 143
2= 120 dry, 143 oiled
4= 143
6= 136
8= 137
Intake vacume was:
18.5 @ Idle
20.5 @ 1500-2000rpm
Old Dec 18, 2011 | 10:20 PM
gdstock's Avatar
gdstock
Quite a difference between banks. How many miles on the engine?
Old Dec 18, 2011 | 10:22 PM
Hylander7's Avatar
Hylander7
Originally Posted by gdstock
quite a difference between banks. How many miles on the engine?
114,000
Old Dec 18, 2011 | 10:27 PM
Ugly1's Avatar
Ugly1
Run it.
Old Dec 19, 2011 | 07:24 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Ugly1 -- what does your reply mean?
Old Dec 19, 2011 | 07:28 PM
Probably something to the tune of:
Your numbers actually look pretty good, with the exception of once cylinder...... don't worry about it, just drive it.
Old Dec 19, 2011 | 07:32 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
thank goodness for trans-ma-engine-lingo-lators!!
Old Dec 19, 2011 | 08:07 PM
Ugly1's Avatar
Ugly1
Thanks HeyYou. That is what I meant.
Old Dec 19, 2011 | 09:43 PM
Hylander7's Avatar
Hylander7
Thanks guys, I wasn't really to worried, but thought I would see what ya'll had to say.
Old Dec 19, 2011 | 10:51 PM
Johnny2Bad's Avatar
Johnny2Bad
You could do a leak-down test if it's really bothering you. Will tell you if it's intake valve, exhaust valve, rings, or head gasket. Anything except head gasket (air bubbles in the rad during test) is not really worth worrying about in an engine that otherwise runs fine.
