Need serious help with SCT tuner
I'm considering one of these....I have a 96 with a 5.9,shorty headers magnaflow cat, gibson cat back exhaust, cheesy cold air intake with 4.56 gears and 35s... Everything else is pretty much stock (I think). Would this tuner be a better choice than a 52mm throttlebody? or should I go with the throttle body first? I should add I want drivability power not really top end..
1.7's are in the works but not for a while. Remodeling the kitchen has priority..
I was thinking the same thing but I have no evidence of death flash that I can find.....I wish my code readers would pick up flash revisions...I wonder if the pc software will do that?
Is death flash even an issue on the older trucks? What about Torque Management?
The tunes you get with the sct are better than what's there stock. You will get more out of mods after the tuner, than you do on the stock programming.
Reprogramming the speedo on the 96 is as easy as changing the driven gear on the VSS in the trans. less than 30 bucks. No tuner needed.
https://dodgeforum.com/forum/2nd-gen...-question.html
Death Flash, It depends on if it's been to dealer.
And your right about the speedo gears if you like tranny fluid running down your arm and laying under your truck everytime you change tire sizes. I for one, would rather push a couple buttons.
I have the SCT from Hemi in my 96 and it is mostly stock.. After some fine tuning and several rewritten tunes from him for a trans shifting problem.. I will say it does everything better.. He never asked for more money or complained about the many program changes and questions, I can not recommend him enough..
Doesn't EVERYONE love assorted automotive fluids running down/into various body parts???
That sounds more like a hardware issue, than software, considering it worked correctly with stock shift points, and hemi's tune..... Would be interesting to try the tuner on another truck.
How often do you change tire sizes?????
