A/C - Heater controls
Old Dec 21, 2011 | 11:57 AM
Tparkin's Avatar
Tparkin
Default A/C - Heater controls
Since I have owned my 01 Ram 1500, the climate control **** fails to adjust from anything other than wide open hot or wide open cool...there is no in-between. I have considered getting a replacement control for the dash from a salvage yard but I am curious if anyone else has expereienced this and if it potentially leads to a bigger problem somewhere. Is there any way to do a quick resistance check on the control **** to determine of it is functioning?
Old Dec 21, 2011 | 03:17 PM
You probably have a broken coupler on the the little servo motor that actually moves the blend door. Have a look Here, and see if that doesn't match your symptoms.
Old Dec 21, 2011 | 03:52 PM
Tparkin's Avatar
Tparkin
how ironic. The reason I posted this was because I watched an episode of 'Truck U' last weekend where they were installing that same product. I guess I'll have to tear the dash apart to confirm, huh?
Old Dec 21, 2011 | 05:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
No you don't. It's not real easy to get to one of the screws for the little motor, but you don't have to tear the dash out.
Old Dec 21, 2011 | 06:38 PM
Bottom of the heater box, right above the trans tunnel on the passenger side. Stick your head under there, you will see it.
Old Dec 27, 2011 | 07:52 PM
Tparkin's Avatar
Tparkin
Thanks guys, I found it. It looks like the motor operates when changing position with the temp control so I'm sure its a broken coupler. As soon as I get a chance to remove it I will confirm.
