needing some transmission help
Old Dec 21, 2011 | 01:39 PM
01PurpleHaze's Avatar
01PurpleHaze
Default needing some transmission help
i have a 98 ram 2500 with a 5.9L 360 automatic 4x4. will a 4x4 auto trans from a cummins bolt up and work in my truck?
Old Dec 21, 2011 | 03:10 PM
No, bellhousing bolt pattern is different. You need a trans out of a gas engine truck. (v-8 as well, the six banger used an even whimpier trans....) Try and stick with 98 or 99 model year as well, others will require changing some sensors, and possibly governor body assembly as well.
Old Dec 21, 2011 | 03:37 PM
01PurpleHaze
ok would it matter if the engine is out of a 95?
Old Dec 21, 2011 | 03:38 PM
01PurpleHaze
the engine had everything switched from old engine to make it work
Old Dec 21, 2011 | 03:45 PM
There were some differences on flex-plates, and torque converters..... basically, where dodge put the balance weights. (360 is external balance.) I think it changed around 98? So, get a torque converter that matches the year of the flexplate on the engine.
Old Dec 21, 2011 | 03:56 PM
01PurpleHaze
so if i use a 98 flex plate use a converter and trans for 98 and if i use the 95 flex plate use a converter and trans 94-97?
Old Dec 21, 2011 | 04:47 PM
Augiedoggy's Avatar
Augiedoggy
no 94 and 95 used a 46rh hydraulically controlled tranny instead of the electronically controlled 46re on the 96 up...but they changed a bit in 97 or 98 I believe. The computers are totally different before 96
Old Dec 21, 2011 | 04:52 PM
01PurpleHaze
so basically as long as i use a 96 or newer trans i should be fine?
Old Dec 21, 2011 | 04:54 PM
Augiedoggy's Avatar
Augiedoggy
like hey you said they made some small sensor and design changes to things... you may have to swap some stuff from your old unit.
Old Dec 21, 2011 | 04:58 PM
01PurpleHaze
ok thanks for the info
