Sct help/questions
Old Dec 24, 2011 | 11:46 AM
kejobe's Avatar
kejobe
Default Sct help/questions
Just got a SCT from Hemifever the other day. I loaded the 93 tune and pinged BAD. So I loaded the 91 tune and it will still ping, just not as bad. The 87 doesn't ping at all.
I've been running 93 gas for over a year now.
I recently (couple weeks) changed back to a 192* stat for the better heat.
Now, I would like to run the 91 tune, but with the pinging I obviously can't.
What can be done so that I can run the 91 safely? It pings with 93 gas as it is.
Would changing back to the 180* stat make a big enough difference that I could run the 91 without problems?
Should I contact Sean about this to see what he has to say?
I'd rather not de-tune if I can help it.
Old Dec 24, 2011 | 11:52 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If heat is not an issue, you could try the 180 I suppose. Your in Ohio, I'd leave the 195 in and see what Sean has to say.
Old Dec 24, 2011 | 11:53 AM
J415's Avatar
J415
When you run the 93, 91 or 87 tune, do you run that gas in it as well with it?
Old Dec 24, 2011 | 12:00 PM
zman17's Avatar
zman17
OP says " I've been running 93 gas for over a year now."
Old Dec 24, 2011 | 12:05 PM
Jimythefan's Avatar
Jimythefan
Just thinking out loud here.
Are you running a brand gas (Mobil, Sunoco)or the local stuff (Bob's gas and go)?
You're in Ohio, do they run a lot of ethanol in the fuel there?
I have Hemifever's tuner too. If I run local gas it'll ping on the 91/93 tune, but with national brands it won't. It really likes the 93 I get at Shell.
Old Dec 24, 2011 | 12:16 PM
kejobe's Avatar
kejobe
Been mostly Giant Eagle's Get Go brand 93 which is "up to" 10% ethanal.
I just tried a local station with 0 ethanal, 100% gasoline and it made it worse. So when that burns out I'll go back to Get Go for the 93.
Might add some octane booster to what's in there now to try and help.
Old Dec 24, 2011 | 12:17 PM
J415's Avatar
J415
That was just a test to see if you were listening... congratulations, you passed.
Old Dec 24, 2011 | 12:27 PM
zman17's Avatar
zman17
LOL, I hate test's. Merry Christmas bud.
Old Dec 24, 2011 | 12:34 PM
J415's Avatar
J415
Likewise Z! To you and your fam!
Old Dec 24, 2011 | 01:20 PM
kejobe's Avatar
kejobe
OK NOW... HAPPY HOLIDAYS TO YOU ALL!!
Now that that's out of the way, , just to update a little, I just e-mailed Sean, so I'll see what he says also.
