Doing a 318 uplift, Hot Ram to go.....
Old Dec 25, 2011 | 07:01 PM
Iggy07's Avatar
Iggy07
Cool Doing a 318 uplift, Hot Ram to go.....
Dont see many 318's upgrades. so got myself a 318 long block and doing some mods. have heads off, and doing some measuring. Not sure how to determine P/V clearance, any suggestions? This i hope will allow me to get block machined and 360 heads and to choice a cam. the one in mind is the XE268, bore is .040 over, 1.5 to 1 valve train (stk) should get me where i want, so any suggestion on the piston/height clearance?
Old Dec 25, 2011 | 08:00 PM
grox's Avatar
grox
Stock rocker lift is 1.6 to 1. Can't help with your clearance question though.
Old Dec 25, 2011 | 08:24 PM
CPTAFW163's Avatar
CPTAFW163
1. 318 upgrades are the same as 360 upgrades. They are both the same block.
2. You really won't have to worry about P/V clearance if you stick with 1.6 roller rockers. You will need a heavy duty spring set to run an aftermarket camshaft.
Here is a good camshaft read:
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
Basically get a camshaft with 200/206 duration and .480 lift (You might be able to get away with 1.7RRs on that cam). I would NOT go above .510 lift even on 1.6 roller rockers on a 318.
aimforsquirrels was a guy who had PVC issues on his 318. I beleive he had to scrap his 1.7rrs to make his camshaft work. He has some thread about PVC here and a special tool that can cut valve reliefs at the proper angle (It is a drill bit that goes in place of the valve. You put it in the head, then put the heads on to spec and drill reliefs).
Hope it helps. I would get an RV camshaft and a SCT from Sean with a custom tune.
Old Dec 25, 2011 | 09:16 PM
Slap a little clay onto the top of the pistons, install the heads/valve train, roll the engine over a couple times, (and hope the valves don't hit.... that's why ya do it by hand....) pull the heads, measure the clay.
Old Dec 26, 2011 | 12:30 AM
gdstock's Avatar
gdstock
Hey! That's like cheating and peeking in the combustion chamber! Cool idea!
