Help with steering column
Old Dec 28, 2011 | 06:56 PM
offroadjosh's Avatar
offroadjosh
Default Help with steering column
Got a broken clock spring in my column and need a new one. new one is wayyy spend, so i found one at a JY (whole column, airbag, key..etc..) for 75 bucks. Its out of a 1997 with all the same features as mine. will it fit? His book said 94-96 works and 97-98 works but not 97 in a 96... Guessing its due to the OBDII change in 1996. Mine is OBDII made in 7 of 96. So I am guessing it will fit?
Old Dec 28, 2011 | 07:46 PM
gdstock's Avatar
gdstock
You might check the parts manual and see if it lists the same one or different part numbers. Don't know if it will fit or not.
Old Dec 28, 2011 | 08:19 PM
offroadjosh
Looked there, wasn't much help. Hoping someone might know.
Old Dec 28, 2011 | 08:22 PM
Be careful with the column, that you don't spin the steering wheel. that's what breaks the clockspring....
I don't see why it wouldn't fit...... very little changed from 96 to 97. I would think it would bolt right in.
Old Dec 28, 2011 | 08:45 PM
offroadjosh
That was my thought. Yea I am going to have to be ultra careful. duct tape it straight=P
Old Dec 29, 2011 | 01:34 AM
97tn4x4's Avatar
97tn4x4
As far as i know there werent any changes in 96-97 that would make it not work. Everything was pretty much the same until 98 when whole lot changed lol.
