Window regulator rollers broke
Old Sep 13, 2009 | 11:05 AM
  #21
Sheriff420's Avatar
Sheriff420
dakota, you had better keep a plastic bag and some duck tape in your truck until you get a new window motor just in case it decides it doesn't want to roll up one day and it starts to rain. its either that or just keep it up until the new motor comes in.
Old Sep 13, 2009 | 06:51 PM
  #22
dakotas ram's Avatar
dakotas ram
so the regulator and motor are the same?
Old Sep 13, 2009 | 07:30 PM
  #23
aim4squirrels's Avatar
aim4squirrels
no, but most times they are sold as an assembled unit.
Old Sep 14, 2009 | 12:18 AM
  #24
dakotas ram
cool, i found this one...anything i can do to prolong th life of the one one i have now....what exactly is messing up on it?
http://cgi.ebay.com/ebaymotors/94-01...Q5fAccessories
Old Sep 14, 2009 | 08:59 PM
  #25
aim4squirrels
stop rolling it up and down.
As to what exactly is wrong, you'd have to remove the interior door panel and visually inspect it moving up and down. If it's just sticking a bit, try white lithium grease in the spray can so it don't stink up the truck.
Old Sep 15, 2009 | 03:40 PM
  #26
rcs4787's Avatar
rcs4787
Default It worked! no problems for a month, Thanks.....
Originally Posted by Sheriff420
low speed with extremely light pressure, just barely touch it. a pair of slip joint pliers should hold the roller just fine provided they have the oval opening in the jaws when closed. and make sure your drill bit is sharp.
The window is now working. I used 3" C-clamps to push rollers on arms with very little pressure. Thanks again guys
Old Oct 18, 2010 | 11:57 AM
  #27
Sheriff420's Avatar
Sheriff420
Well this is an old thread, but it was the one I was looking for. I knew there was a cheap fix for this issue.
Here's a picture of the broken roller and where it goes.
And here's a video of what it sounds like when that thing is broken.
http://www.youtube.com/watch?v=Xva8tdnzkyQ
Old Oct 18, 2010 | 01:34 PM
  #28
J415's Avatar
J415
I've got that same noise when I roll my windows. I never knew that was a problem. So where do you pick up those rollers?
Old Oct 18, 2010 | 01:40 PM
  #29
Sheriff420's Avatar
Sheriff420
Home Depot or Lowes.
The rollers for drawer slides are apparently the same size, or close enough that you can modify them a little bit so they'll fit.
I'm on my way to Lowes here in a few minutes.
Old Oct 18, 2010 | 06:19 PM
  #30
J415's Avatar
J415
Good deal...thanks for the heads up. All this time I thought that that noise was just a dodge being a dodge...
