Window regulator rollers broke
Old Oct 18, 2010 | 06:26 PM
  #31
Sheriff420's Avatar
Sheriff420
I couldn't find any close enough to the right size at Lowes but I have to wait for my dremel to get back from the warranty claim anyway so I've got a good week or so to find something that will work.
Old Oct 18, 2010 | 07:53 PM
  #32
J415's Avatar
J415
If you know the size that you need and you can't find them there, I have no problem looking over here for you. Just pay what it cost and a 44 cent stamp and you got it.
Old Oct 19, 2010 | 09:08 AM
  #33
Sheriff420's Avatar
Sheriff420
Sounds good to me, I'll get back to you with pictures/measurements tomorrow. I'll put them in this thread for the people with the same issue in the future.
Old Aug 14, 2011 | 10:09 PM
  #34
sam maes's Avatar
sam maes
Hey guys, had the same problem and followed your instructions...seems to be working just fine, thanks for posting this what a savings!
Sam Maes
Old Jun 8, 2017 | 05:44 PM
  #35
Chris Cecil (Robosprout)'s Avatar
I designed and 3d printed some rollers that snap onto the stock pins. All that is required is that you bend out the tabs at one end and slide them in the rail. I just made them today so it will take some testing to see how well they hold up but it is very nice not having to remove the regulator to fix the issue.
Here are some pics.
https://flic.kr/s/aHsm2ag3Cu
For those who have printers: I printed these with PETG filament with 100% infill on a .3mm nozzle.
By the way...this was on a 98 Ram Quad cab that only has 68k original miles. Time seems to be the factor on these parts over mileage.
Old Jun 9, 2017 | 11:13 AM
  #36
Sheriff420's Avatar
Sheriff420
Here are some pics.
Looks good, don't forget to smother that rail in grease.
I found some of the push clips for the door panel on ebay for a ford that were a little bit too big so I had to do one cut down the center with the band saw to remove a little meat to make them fit. I got those because they were $5 for 25 but the dealer and body shops wanted $3.50 each. If you do a little digging online you might be able to find the right size at a decent price.
I got a piece of PTFE and drilled a hole through it then left it on the drill bit so it would be perfectly round and had the bit spinning while I shaped it on a band saw.
Old Oct 24, 2017 | 05:20 PM
  #37
jhughe90's Avatar
jhughe90
Just did the roller fix today on my '99. I ran across this YouTube video describing pretty much the same thing:
Prime-Line 4-Pack 7/8-in Dia Flat Edge Nylon Ball Bearing Sliding Shower Door Roller
$3.30 at Lowes, no Home Depot in my area had them in stock. Clipped the plastic off and just used the metal. Cut off the old roller metal ***** and drilled a hole for the screws. Tightened well and greased all the tracks and joints up.
One other warning I'll mention is to put your window regulator halfway down before removing it. Otherwise I couldn't get the bolt holes to line up putting it back in.
Old Oct 26, 2017 | 01:06 AM
  #38
brian102's Avatar
brian102
y'all know brand new regulators are about $20 on rockauto...
Old Oct 27, 2017 | 01:41 AM
  #39
Sheriff420's Avatar
Sheriff420
The regulator isn't what breaks. I used some teflon plastic that I already had to fix mine when they broke because it cost me $0.
Old Oct 27, 2017 | 09:04 AM
  #40
brian102's Avatar
brian102
Lol. I know, I have the same problem with my passenger side. Wheels are frozen, and the original grease hardened into something resembling bee's wax. Free Teflon is a great fix, but I saw guys spending about the same as a new regulator.
