Window regulator rollers broke
Old Apr 4, 2018 | 04:53 PM
  #41
SyFry's Avatar
SyFry
Are you able to ship some of these out? I could definitely use a bag of whichever you found works best. My rollers just snapped and I am looking for an easier fix than drilling out the tracks.
Old Jul 8, 2018 | 01:34 PM
  #42
MonstaDriva's Avatar
MonstaDriva
Deleted
Old Dec 29, 2018 | 06:39 PM
  #43
Cliff Lynn's Avatar
Cliff Lynn
Fixed mine with parts from Home Depot. Hardware drawers. Bought a Nylon Spacer 1/4 ID X 5/8 OD X 3.8 Long. UPC Code 87480 15078. Sanded it down to roughly the same thickness as the original parts. Took a 7/16 spade drill bit and removed material from the inside to accommodate the head of the bolt. Used a 3/8 drill bit to round out the bottom of the Nylon spacer. Install a flush head #12 X 3/4 inch machine bolt and attached a flat washer and #12 nut to the exterior to lock the new bushing together.
Next I drilled out the nipple connectors on the regulator and slid my new bushing into the track (after test fitting several times). Then connected the screw/bushing to the regulator with flat washers on both sides a
The raw part from Home Depot (in the bag) and my manufactured bushings.
Bushing in the Home Depot Bag and my manufactured replacements.
New Bushing assembly on the left. Three unassembled parts on the rght.
Original Busing is on the Right. The three parts unassembled in the middle and the finished replacement busing on the left.
d a second #12 nut on the exterior secured with Loc-Tite thread compound. Worked like new.
Old Jan 4, 2019 | 02:31 PM
  #44
USN retired airedale's Avatar
Default Window regulator
Does anyone know who manufactured original regulators. Tyco, AC Delco, VDO?
Old May 31, 2023 | 09:31 AM
  #45
Parker Ladd's Avatar
Parker Ladd
Do you have the stl for the rollers?
