Last edit by: IB Advertising
Browse all: General Overview
- Dodge Ram 2nd, 3rd Gen Buying Guide
Important information to help you understand your Ram.
Ebay LED buying guide for 2nd gen dodge ram
#21
To compensate for pupils that are constricted because I keep my panel lamps too bright? Nah. They're so I can see further down the road and avoid those deer, elk, moose, and worst of all, angus cattle that might otherwise end up in my grille -- and I can see further whether on low beams or high with my panel lamps dimmed. That's why they put that rheostat in the switch, after all.
Yeah, I'm kinda **** about things like that. I prefer to avoid wrecks.
Then again with so many rednecks with HID's in there factory headlight housings blinding me it doesnt matter much about my pupils adjusting...
#22
I used all ebay lights for my transformation
Topper light with LED panel, also have two 3ft stripes to hook up yet under the bed rails
Same panel in dome as the topper, then smaller 12 LED panel in the map lights
This is the same as the stripes in the bed
Dash lights
Video of the rear lights
I want to replace the rear red lights with the spider LEDs or ones with more LEDs. I also need to do the front turn signals.
Dash lights
#25
@wermbang what color and type of led's did you use? that IC does look a bit bright. i don't know if led lights will work up front. on my trucks i have never had any luck installing led's up front. when i would turn my lights on the the dash turn signal light would come on and stay on for the the side that had the LED light installed.
#26
In person its not that bad at all. They are ones that have 4 leds out the side then a high power on the top. For the turns to work properly need to install resistors
Video
here is the dash with old bulbs
Stock vs LEDs (old ones that have been replaced) notice the hot spots
For the underhood light mine is hooked up to the stock one, so it goes on and off as normal. Just needed to put the wires on the correct side.
Video
#27
EDIT:I did a quick search and didn't come up with the flasher relays so it looks like the resistor is the only option.
#28
#30
i could understand needing one of those if you had leds front and rear but i only tested a led in one socket at a time to see what it looked like. when i tested it in the one of the front sockets the turn signal light in the IC would turn on for the side i installed the led light when i turned the marker or headlights on even with the turn signals off. now when i install them in the rear everything worked correct except that they where not bright enough to be safe.
