Excessive Positive Camber
Old Jan 4, 2012 | 07:38 PM
  #21
kejobe's Avatar
kejobe
Doesn't make any sense though, does it? I would have thought they both would install from the bottom so as they both would help support the weight.
Old Jan 4, 2012 | 07:41 PM
  #22
kejobe's Avatar
kejobe
Originally Posted by CSCustomCars
The knuckles separated from the ball joints fine. The hubs wouldn't come the hell off for anything. The ball joints were original as are the hubs so they did not want to come out, but they did.
Really I had no problems taking it apart or putting it back together.
Maybe my theory was inaccurate then. Did you happen to notice if there was positive camber before you replaced the BJs?
Old Jan 4, 2012 | 07:44 PM
  #23
CSCustomCars's Avatar
CSCustomCars
Yes there was, but the joints were bad, which I figured was contributing to it.
But now, its bad on both sides, where as when the joints were bad, it was only noticeable on the passenger side. The driver side ball joints where no where near as bad as the passenger side, but that side had about half the camber of the passenger side.
Old Jan 4, 2012 | 07:50 PM
  #24
kejobe's Avatar
kejobe
Puzzling to say the least. I would still have to lean towards something being bent. Might want to get it up on the rack at first chance to have a better look and get measurements.
Old Jan 4, 2012 | 07:56 PM
  #25
CSCustomCars
Yeah I guess something has to be bent. I just don't have a clue.
Maybe my knuckles are bent...
Old Jan 4, 2012 | 07:59 PM
  #26
Wh1t3NuKle's Avatar
Wh1t3NuKle
So what do you guys think here? Is this beast lifted?
I was just merely pointing out there was a spacer.
Is it possible the toe-in is too much such that it gives the appearance of positive camber? These are new BJs. Any indication that the tie rod ends remain in decent condition?
Old Jan 4, 2012 | 08:16 PM
  #27
CSCustomCars
No worries dude, like I said, I'll admit it if I'm being an idiot. I thought that was factory, its not, so I was wrong. No big deal.
And the tie rod ends are new as well, they've just been undercoated since I put them on, so they look old.
Old Jan 4, 2012 | 10:11 PM
  #28
dsertdog56's Avatar
dsertdog56
I'm sure you checked them...but I have to ask. Are your hub bearings tight? You must have put new ones in with the ball joints?
Toe in that was my 1st thought too.
Scrap those..I wonder if you have the wrong knuckles. I don't think you could reverse them because the brakes would be upside down. So would your tie rod tapers. But I wonder if you have some from another year ram...or something else? Any knuckle from a D60 with ball joints could interchange.
Old Jan 5, 2012 | 12:30 AM
  #29
Sheriff420's Avatar
Sheriff420
Are you sure you got the right ball joints?
Did you compare them to the old ones when you took them off?
Did the hub bearings seat all the way around when you put them back on?
Old Jan 5, 2012 | 12:39 AM
  #30
offroadjosh's Avatar
offroadjosh
Throw a level on the axle C-ears if you can(ya i know pain in the ***). should be level up and down if im correct...
