Lift Kit question
Old Jan 4, 2012 | 02:52 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Master merc!
Referring back to this post.
Sure enough with the Body Lift its at 46" for both.
What ya checkin' boss?
Old Jan 7, 2012 | 04:19 PM
dodgereadysetgo's Avatar
dodgereadysetgo
I have a 05 dodge ram i am looking to lift 2 in. what is the best kit for that truck? and if i put 17 in wheels on it what size would best fit this truck with a 2 in lift. street and pasture use mostly!
Old Jan 7, 2012 | 05:04 PM
kejobe's Avatar
kejobe
Wrong section. You need the 3rd Gen section. Although someone here may know.
Old Jan 7, 2012 | 07:28 PM
BackwoodsRam's Avatar
BackwoodsRam
Fyi 37's will fit on a 6 inch lift. With a 7 inch lift 35's look small
Old Jan 7, 2012 | 07:43 PM
merc225hp's Avatar
merc225hp
Originally Posted by Wh1t3NuKle
Thanks Sir, More or less just reference material. If you are curious I sit at 45"
Old Jan 7, 2012 | 07:47 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 & Wn can you guys measure from the ground to the top of the inside of wheel well on the front of the truck. I am curious about your trucks hieght.
As for the lift the best advice I can pass on is do it once and do it right.
Don't know how I missed this but I'll measure when i get home for you. As far as 35's looking too small, I know my fenders will disagree with you on that one. I know for a fact with 37's on my 7" lift i could crunch my fenders. I'm also not a fan of the "stuffed in there" look. I like some distance between my tires and fenders.
