Please help!!!
Old Jan 5, 2012 | 09:55 AM
a32ozSlurpee's Avatar
a32ozSlurpee
I will try that. I am also going to film a video....maybe it will help
Old Jan 5, 2012 | 10:25 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yep. Shore does. Back of the motor, passenger side. You need an arm with three elbows to remove it. Don't even think you are going to be able to actually see it....
We need to know where to get one of 'dem tools! Double jointed work any?
Old Jan 5, 2012 | 10:32 AM
DodgeLooney00's Avatar
DodgeLooney00
If you do have a Vacuum leak, and hve trouble pinpointing it... get some starting fluid and spray it near the vacuum hoses, around the throttle body gasket, intake manifold gaskets... if you hear the idle drop, thats where your leak is...
Old Jan 5, 2012 | 04:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Also, the negative battery cable should have been disconnected FIRST, before any work. That and cheap replacement parts may be the issue. Did the bore in back of the TB get cleaned before installing new IAC? https://dodgeforum.com/forum/dodge-r...n-the-iac.html
