real quick plenum question.
Old Jan 6, 2012 | 07:56 PM
mstephen89's Avatar
mstephen89
Default real quick plenum question.
okay so everyone always sais look for a pool or a puddle of oil in the back of the intake, to determine if the plenum gasket has failed, so i took off my throttle body a few minutes ago, and i definately have some oil, but probably only about 1/16-1/8" deep, and only in the very rear most part of the intake. Is the plenum shot? okay peeps, lets see who can respond first....ready....set....go, lol
Old Jan 6, 2012 | 08:02 PM
Mikester1's Avatar
Mikester1
I have the same thing, but not that much oil. You will get a little oil from the PCV. But my question is how much? Or is that a sign of a defective PCV valve, even if it rattles?
Old Jan 6, 2012 | 08:06 PM
sam_priem's Avatar
sam_priem
if there is any oil in your intake manifold, the gasket is shot. there doesnt have to be much in there. when i did mine i had a real thin oil film in there and when i took the manifold off the gasket was destroyed. its not difficult to fix it just takes a little while to get everything removed and out of the way. when you go to replace the gasket, replace the plate and bolts holding it there. hughesengines.com has a complete kit to do it.
Old Jan 6, 2012 | 08:10 PM
sam_priem's Avatar
sam_priem
how many miles on it?
Old Jan 6, 2012 | 08:17 PM
mstephen89's Avatar
mstephen89
125,000... i have read everything on the site, and i fully understand the plenum, i was just curious if what seems to be a small amount of oil, is enough oil to definately call it(plenum gasket) bad.
Old Jan 6, 2012 | 08:27 PM
sam_priem's Avatar
sam_priem
with just a small amount of oil in it, it might be normal. im not too sure. its hard to say with only 125k. most of the time when people find oil pooling in the manifold, its more of a confirmation that the gasket it bad. usualy there are other symptoms like missing, chugging under load, loss of power ect.. but like i said its easy to do as long as you have time to do it. if by chance the gasket is still good, its still not a bad idea to replace it along with the new plate and the whole works just as a precaution. if the gasket hasnt gone out yet, it WILL if you leave the stock plate in.
Old Jan 6, 2012 | 08:33 PM
TurboStixx's Avatar
TurboStixx
If it is pooling at 1/16th to 1/8th inch, your plenum is more than likely shot. I just replaced mine, I have a film of oil in my intake (a tiny film) but that is from the PCV valve.
To replace the plenum...go to this post
https://dodgeforum.com/forum/1st-gen...ml#post2678319
Old Jan 6, 2012 | 08:34 PM
TurboStixx's Avatar
TurboStixx
Film or pool?
Mikester1's Avatar
Mikester1
OK, answer this one for me please, I have less then 1000 miles on my engine, and did the hughes plenum repair, and have oil. PCV valve?
Old Jan 6, 2012 | 08:38 PM
sam_priem's Avatar
sam_priem
less that 1000? is that a typo or do you just not drive it much? and more than likely if the gaskets are new its the PCV. make sure its motor oil though. ive heard of people having brake fluid sucked into the manifold from the brake booster.
