Oil pan gasket/rear main seal (oil leak)
Old Jan 8, 2012 | 04:38 PM
  #31
Its 40+ degrees here in michigan today, worked outside most of the day, and was actually sweating... That hasn't happened for a while.
Are you trying to use a 3/8ths ratchet on that bolt?
Old Jan 8, 2012 | 04:45 PM
  #32
BigBlue83's Avatar
BigBlue83
a 16mm
Old Jan 8, 2012 | 04:49 PM
  #33
Drive size on the ratchet...... I used a 1/2 inch drive, and while it was a bear, and fought the whole way, it DID come off.
Old Jan 8, 2012 | 04:57 PM
  #34
BigBlue83's Avatar
BigBlue83
oh yes i am sorry with a 3/8 extender
Old Jan 8, 2012 | 04:59 PM
  #35
You need something meaner for those bolts, or, grab a piece of pipe that will fit over your ratchet handle, to give you a bit more leverage. Once you get it to break loose, it should come off without too much fight.
Old Jan 8, 2012 | 07:03 PM
  #36
BigBlue83's Avatar
BigBlue83
Yea my pipe is too long it wasnt fitting. A buddy of mine came through for me. He brought his 1/2 inch driver and 5 min later I had the starter in my hand. I have some pics for u guys. All thats left is the oil pan too dark and cold
Old Jan 8, 2012 | 07:36 PM
  #37
Yeah, I HATE working outside in the winter....... that sucks. There are a BUNCH of oil pan bolts..... hope your health insurance covers carpal tunnel.
Old Jan 8, 2012 | 08:31 PM
  #38
BigBlue83's Avatar
BigBlue83
No ****, i counted 18 bolts. maybe ill get the power drill to take them all off
Old Jan 8, 2012 | 08:51 PM
  #39
BigBlue83's Avatar
BigBlue83
BEFORE
AFTER (will try clean some more)
  #40
mccart's Avatar
mccart
And if you got a rubber gasket, your going to need longer bolts. I did that, but it was 11 o clock on a sunday night so we put the jack under the pan and compressed the gasket
