Front end problem
Old Jan 9, 2012 | 12:08 PM
RAM 25's Avatar
RAM 25
Default Front end problem
I have a 98 Ram 4x4 2500 quad cab long bed. I recently replaced all the tie rods, ball joints, shocks, steering shaft, and tires(285/75/16). I had it aligned and still had this wandering problem. I then replaced the track bar, it helped a little but I still have a wander problem.
If I am going straight down the road and have my hand positioned on the steering wheel at 12 o' clock, I constantly have to move from 11 o'clock to 1 o'clock to keep it going straight. Any idea what I'm missing here?
Could it be the steering box worn out? Should I have had it realigned after the install of the track bar?
I bought this thing a couple months back and the previous owner obviously never took care of it. It shows about 270K on the mileage and judging on the condition of the front end when I bought it it leads me to beleive that it could very well be a bad steering box. I have not tried to adjust the box, I heard that is a possibility, not sure on how to do it correctly. Any advice would be appeciated.
Old Jan 9, 2012 | 12:13 PM
Do you still have slop in your steering? If so, box is pretty high on the list of suspects. (and a fairly standard problem....) You can try and adjust the box a bit. There is a DIY in the faq section, and a bit more involved procedure in the factory service manaul. (which is also available in the faq section.)
Some folks familiar with the dodge trucks also recommend running around 3* of caster up front as well, to increase the tendency for the steering to want to self-center. (being self centered is good for steering, bad for people.....)
Welcome to DF.
Old Jan 9, 2012 | 12:14 PM
mcweaver's Avatar
mcweaver
is there play when you move the steering wheel from 11 to 1 or does it respond when you move it? It definitely could be the steering box, and getting it re aligned wouldnt be a bad thing...
Old Jan 9, 2012 | 12:21 PM
RAM 25's Avatar
RAM 25
With the truck parked and not running I can see that it appears to respond when turning from 11-1 not alot but I do see some movement though.
Old Jan 9, 2012 | 12:23 PM
RAM 25's Avatar
RAM 25
Thanks for you help, I will look at the faq section.
