95 Ram 1500 Overheating?
I've got a 95 Ram 1500 w/360. It keeps overheating. I have replaced the thermostat and water pump, and the radiator seems to be flowing fine. I can hear the fan clutch engage and dis-engage. And the radiator cap tested good. I also recently replaced the heads, but it was overheating before and after the heads were replaced. I'm not sure what else it could be, or if there is something I missed. Any help would be greatly appreciated. Thanks.
I have a '97 Ram 1500 and similar issue. Put a drop light to the radiator coil and make sure your fins in both your radiator and the condenser (A/C) coil are all clear. You should be able to see right through. If you do any off-roading, and even just the age of the vehicle, mud/dirt, gets caught in the fins and can block enough of the air getting through to cause you problems not to mention it will also affect your transmission cooling. I found this out the hard way.....
Sorry.....forgot to mention not to use compressed air to clean coils. Use a regular water hose with a spray and gently wash until coils are clear. You might be surprised how much dirt and grime will come out. Hope this helps resolve your problem.
