LED knowledge please!
Old Jan 9, 2012 | 09:51 PM
chromed95's Avatar
chromed95
Default LED knowledge please!
I'm thinking about putting the LED light bar on my truck, you know the one that runs below your tail gate and has the essential functions (brake, turn, running), and just want to know if when I hook it up, will my turn signals be on crack? By crack I mean blinking really fast? Or does that only happen when I COMPLETELY replace my turn signals with LED's while using the stock relay for signals? Thanks guys!
Also if any of you have light bars and like them, or know of any good brands and where to get them let me know! Thanks
Old Jan 9, 2012 | 10:33 PM
crazzywolfie's Avatar
crazzywolfie
LED's react quicker than normal lights so they will always seem like there on crack when compared to the other light
kejobe's Avatar
kejobe
Any that I have seen blink normal in sync with the OEM lights.
Old Jan 9, 2012 | 11:21 PM
Cheat's Avatar
Cheat
They blink at the same rate because they are wired in parell to the oem lights therefor it doesn't effect the amps pulled on the flasher, there for they are still gonna flash normal. Now, with a total led replacement, either big resistors or electronic flashers must be used.
Old Jan 10, 2012 | 08:28 AM
EndIsNear's Avatar
EndIsNear
That LED strip most likely already has load resisters built in line. It should blink just fine, but will fully illuminate a hair quicker than your stock bulb blinkers.
Old Jan 10, 2012 | 09:26 AM
jmbishop's Avatar
jmbishop
No, probably not because it doesn't need a load resistor. Like Cheat said, a load resistor is only necessary if you've replaced all your signals with LEDs.
I don't like light bars though, the first time I saw them I thought it was a cool idea but I hate a few things about them now.
1. There is always a diode or two that is out, it drives me crazy
2. They put no lens on the LEDs to defuse the light, I would prefer a even glow across the whole strip and not the bright spots from the LEDs.
Old Jan 11, 2012 | 06:20 PM
LegendKiller89's Avatar
LegendKiller89
I have one. Blinks just fine.
Old Jan 11, 2012 | 08:34 PM
chromed95's Avatar
chromed95
thanks guys. Ya the only thing I don't like about them is the one diode that goes out and makes it look not as good. but other than that they are relatively cheap and easy to install
