snapped ball joint WITH PICS!!!!
Old Jan 10, 2012 | 11:47 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by dipsherry
so sunday out playing and felt like front shaft went...well when i pulled it out of the hole this is what we found...broken uper and lower ball joints, bent tie rod end snapped axle. So my question is where can a get a upgraded axle for the d44 i am running lockers front and rear and i dont want to continue to snap axles. Also what is the best ball joints to get and what is the best tie rod end. I use my truck as a weekend toy and i play hard.
I just came across this article. Until there is a good find on an axle swap, my primary method to improve the d44 is to reinforce the C.
http://www.4wheeloffroad.com/techart...xle/index.html
Old Jan 10, 2012 | 01:43 PM
dipsherry's Avatar
dipsherry
sweet thanks that helps i just dont have 5 grand to build a new set of axels...gotta see how long the half tons will hold out
Old Jan 10, 2012 | 01:51 PM
dipsherry's Avatar
dipsherry
Better read the fine print.
yeah my truck is stock height and never sees extreme driving or off road driving *wink wink*
Old Jan 10, 2012 | 02:14 PM
1986JEEP's Avatar
1986JEEP
If i was you. Find a king pin dana 60 out of a old ford 1 ton and all the peroblems with balljoints will be gone. jmo. To hell with the dana44 junk.
Old Jan 10, 2012 | 03:03 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I just referred to an article that had a number of things to do.
It will not cost $5K to do reinforce the Cs, which is what I was hedging at you....
Old Jan 10, 2012 | 04:22 PM
dipsherry's Avatar
dipsherry
i was refering to 5k to build a set of dana 70's and dana 60's....part of the reason i want to keep my 44 is cause i got lockers front and rear on my truck now. I worded that wrong. Thanks for the article it gave me ideas to extend the life of these 1/2 ton axles till i save up for the swap...I still have a motor i have to put in lol gotta save as much money as possible for now.
Old Jan 10, 2012 | 04:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There's probably a hundred people on DF that would buy those D44 lockers/axles, if you swapped in D60's.
Old Jan 10, 2012 | 08:51 PM
offroadjosh's Avatar
offroadjosh
ME!!!
Old Jan 11, 2012 | 09:09 AM
dipsherry's Avatar
dipsherry
yeah i figured i would be able to off load them on here just know i wont get the $1200 i paid but i might be able to recover some of it....Just a tidbit on the motor....its built putting heads on today and then its going to go in this week as well
Old Jan 11, 2012 | 10:29 AM
dodgeram07's Avatar
dodgeram07
mmmmm king pin tttthhhhaaaaaaattttttttttssssss nice
long all u lucky that didnt take a **** sum were leass
