snapped ball joint WITH PICS!!!!
Old Jan 11, 2012 | 10:36 AM
  #21
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by dipsherry
i was refering to 5k to build a set of dana 70's and dana 60's....part of the reason i want to keep my 44 is cause i got lockers front and rear on my truck now. I worded that wrong. Thanks for the article it gave me ideas to extend the life of these 1/2 ton axles till i save up for the swap...I still have a motor i have to put in lol gotta save as much money as possible for now.
I understood that. If you have access to welder and sheet metal and cutting, etc. it would be real cheap to gusset the d44 at the Cs. It really would beef it up more. In addition, you could also create your own axle sleeves. The cost then is just the materials, which I'd just venture out to be no more than $300.
yeah i figured i would be able to off load them on here just know i wont get the $1200 i paid but i might be able to recover some of it....Just a tidbit on the motor....its built putting heads on today and then its going to go in this week as well
Beefing up the axle like above would make it more attractive by itself. The locker, if you treat it good, keep the paperwork, etc. will also be more attractive..maybe.
Originally Posted by dodgeram07
mmmmm king pin tttthhhhaaaaaaattttttttttssssss nice
long all u lucky that didnt take a **** sum were leass
wtf no more phone access for you.
Old Jan 11, 2012 | 11:36 AM
  #22
dipsherry's Avatar
dipsherry
ur phone hates you
Old Jan 11, 2012 | 02:53 PM
  #23
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hey Dip,
maybe you already have in mind what d60s you are targeting, but i'll toss this still just in case.
If you get a dodge d60, then be prepared to swap out the knuckles for fords to do the spindles. No sense in keeping unit wheel hub assembly. This way everything else is a bolt up, even the calipers.
Otherwise, go for Ford HP60.
Some tidbits is all dude.
Old Jan 11, 2012 | 03:08 PM
  #24
dipsherry's Avatar
dipsherry
Originally Posted by Wh1t3NuKle
Hey Dip,
thanks for that i am just starting my research on what axles to go with...I am a fan of easy swap and least money....but i think we all are. thanks for the heads up its little peices of knowledge like this that will save me a headache later.
Old Jan 11, 2012 | 03:20 PM
  #25
Wh1t3NuKle's Avatar
Wh1t3NuKle
Alright, I'll compile a bit more for you in due time.
However, you need to get back to updates about the engine....where's your thread?
Old Jan 14, 2012 | 11:49 AM
  #26
97tn4x4's Avatar
97tn4x4
I'm just going the gusset the 44 add lockout hubs chromoloy shafts and joints. 1300 for the lot. I just can't spend the money for new axles then regear and all that.
Old Jan 14, 2012 | 11:55 AM
  #27
For that kind of money, you could do the axles, provided you could find a good deal on some D60's..... and sell your little ones to offset some of the cost.
Old Jan 14, 2012 | 12:31 PM
  #28
97tn4x4's Avatar
97tn4x4
Yeah but them I'd have to regear and all that. My feelings are the 44 chromolies are at least as strong as the stock 60's.
Old Jan 14, 2012 | 12:40 PM
  #29
It's the housing, carrier, spiders, and balljoints that are gonna give ya trouble.
Old Jan 14, 2012 | 05:58 PM
  #30
97tn4x4's Avatar
97tn4x4
Syneregysuspension.com sells a beefy set of balljoints and I'm gonna truss the front end and gusset the c' s up with 2.5"x2.5" 1/4" wall tubing. I think it'll hold up for how I drive lol.
