musty smell coming out heater
Subscribe
Jan 11, 2012 | 02:05 PM
I get a musty smell that comes out of my heater vents in my truck.In the summer the same smell was coming out of the ac vents too.it also comes out of the vents and defroster.what could be causing this musty smell?someone told me they sell something in the parts store to spray in the vents or something to get this smell to stop.anyone have any clue to what its called?thanks
Reply 0
Jan 11, 2012 | 02:24 PM
i don't know how the fresh air intakes are on the newer trucks but on the older trucks they tend to get filled with debris and if it sit long enough it can start smelling. i know on newer cars there is usually a in cab filter.
Reply 0
Jan 11, 2012 | 02:29 PM
You might (probably do) have mold/fungus/some new life form living in your HVAC housing. The best way to fix that is to crack the thing open, scrape out the biologicals, treat with bleach or some antibacterial or fungicidal chemical, and figure out why water is collecting in there to provide a hospitable environment for the unwelcome life form. It could be a plugged drain tube or a leaky heater core.
Reply 0
Jan 11, 2012 | 02:34 PM
Have you lost any damp socks recently?
Reply 0
Jan 12, 2012 | 02:49 PM
Ok thanks for the info everyone vw I really dont see the point in your post guy.anyway I will check it out.
Reply 0
Jan 12, 2012 | 03:02 PM
get a can of Lysol spray, with a smell you can tolerate. I like "fresh linen".
open the doors and leave them open. turn on the ac with fresh air intake so its sucking in outside air through the cowl area of the passenger side. spray a generous amount of lysol into the cowl. you'll see it getting sucked in. repeat several times and do this regularly to kill/eliminate the mold and mildew.
Reply 0
Jan 12, 2012 | 06:28 PM
Also make sure the AC drain hole is not plugged.
Reply 0
Jan 12, 2012 | 10:46 PM
Put a hound dog under your truck.. learn to know the difference between the sound of trailing and treeing.. if that hound bays treed, suspect coons...
I don't know what it is about coons and these trucks.. you're not the first, dude..
Reply 0
Jan 12, 2012 | 11:23 PM
Quote: I don't know what it is about coons and these trucks.. you're not the first, dude..
Oh lawdy, that 5h17 just ain't right.
Reply 0
Jan 13, 2012 | 07:11 AM
Quote: Also make sure the AC drain hole is not plugged.
It could be plugged by a missing sock!
Reply 0
