Keeping truck strong?
Old Jan 13, 2012 | 10:39 PM
king_moaoe's Avatar
king_moaoe
Default Keeping truck strong?
i have 98 1500 5.9 its been sitting for last four months (transmission was blown) just had it replaced but wondering what additives i should use to keep the engine running good. oh yeah it has 180,xxx so going to have engine done next summer so need to keep it running.
Old Jan 13, 2012 | 10:57 PM
mccart's Avatar
mccart
What's it running like now?
Old Jan 13, 2012 | 11:29 PM
king_moaoe's Avatar
king_moaoe
currently it is running fine, the oil bearings are loose so when the oil heats up the oil when i stop will drop in pressure. but right now looking for tips to make sure i don't spend as much as i have on tranny to just get onto the open road and blow the engine from sitting there.
Old Jan 14, 2012 | 12:40 AM
mccart's Avatar
mccart
I'd do an oil change and put a quart of the Lucas stuff in it for now
Old Jan 14, 2012 | 01:36 AM
mccart's Avatar
mccart
Run a can of sea foam thru it too
Old Jan 14, 2012 | 01:50 AM
merc225hp's Avatar
merc225hp
As the trucks been sitting for awhile I would give it a oil and filter change, then using a mechanical oil pressure tester check the oil psi. The oil pressure sending units are not that great on these trucks it might just be the problem.
Old Jan 14, 2012 | 02:57 PM
king_moaoe's Avatar
king_moaoe
so oil change, and check oil psi? and fuel additive i should add or anything like that?
Old Jan 14, 2012 | 03:31 PM
merc225hp's Avatar
merc225hp
For the oil pressure test you will remove the oil pressure sending unit, found at the back of the motor beside the dizzy a real pita to get to, you will need a special socket to remove it. Next using a oil pressure test gauge start the motor and see what results you get.
For a fuel additive try Chevron Techron in the bottle.
Example of a test kit. http://www.harborfreight.com/engine-...kit-98949.html
