how can u tell its hi flow
Old Jan 14, 2012 | 07:31 PM
chadhager03's Avatar
chadhager03
Plenum is on top of the engine on the bottom of the intake manifold.......
Old Jan 15, 2012 | 02:43 PM
gertie240's Avatar
gertie240
Did the magnet test yesterday, its steel, looked down in there, its a little oily, and the thottle body is way dirtier then I thought it would be. Should it not be oily at all? All that I have read, it seems like a full days worth of wrenching plus a good bit of money. Can it be a little oily or is this just the beginning signs before it goes FUBAR.?
Old Jan 15, 2012 | 03:38 PM
Augiedoggy's Avatar
Augiedoggy
the pvc valve lets a little oil in there...especially as they wear out and stick (they are recommended to be changed every 24,000 miles.. A good way to clean it out is with seafoam per brake booster line in the directions (It should smoke a lot)... Then replace the pvc valve and try the seafoam again in a few weeks and see if there's still a lot of smoke...if not there's a good chance the oil is just the norm from the pvc valve...there's another thread here with pics of both blown gasket oil buildup and pvc oil buildup...
Old Jan 15, 2012 | 04:56 PM
gertie240's Avatar
gertie240
I really didnt mean to turn this into another plenum thread. I am going to get a new pvc and a tb gasket from the dealer tomorrow and clean things up . after I have the TB off I ll try to get a picture of the plate and post it here to get some opinions. I saw the posts about good or blown, but once its out u should fix it anyway, so I thought if I got a pick of one before it was pulled it might help others.
