problem
Old Feb 7, 2012 | 10:30 PM
  #71
muddy_ram's Avatar
muddy_ram
Originally Posted by zman17
There not fairly inexpensive like some of the other sensors, so I for one won't tell you to replace it. Your money would be better spent getting a Haynes and testing it. But, I'd remove it and make sure the small hose behind it is not broken first. And I've seen plenty of time's a MAP code coming up, when it was actually some other vac leak or problem.
called around to a few parts places and went to lordco looking around 130 for the sensor the sensor looks fine but ill look for any vacuum line make sure theres no broken 1 too i cant stand my truck being like this
Old Feb 8, 2012 | 06:47 PM
  #72
zman17's Avatar
zman17
Retired Moderator - RIP
You have to remove it to check the little hose behind it that I'm talking about.
Old Feb 8, 2012 | 08:27 PM
  #73
muddy_ram's Avatar
muddy_ram
yup the little hose is fine no splits in it but i cant find how to check it to see if its broken
Old Mar 5, 2012 | 10:33 AM
  #74
muddy_ram's Avatar
muddy_ram
fixed the problem spark plug wires where done
