problem
Old Feb 4, 2012 | 11:25 AM
  #51
Running rich for some reason. Bad O2, or engine temp sensor would do that......
Old Feb 4, 2012 | 04:11 PM
  #52
botta's Avatar
botta
does it have an EGR?(on th rear of the block next to the oil psi sending unit, pass side) mine does and it did that stuff when it was going bad. and my crank sen.(top of the trans housing, pass side as well.)
Old Feb 4, 2012 | 04:46 PM
  #53
zman17's Avatar
zman17
Retired Moderator - RIP
97 should not have an EGR.
Old Feb 4, 2012 | 11:02 PM
  #54
muddy_ram's Avatar
muddy_ram
i did the hole code check thing and it said 32 and 14
Old Feb 5, 2012 | 03:09 AM
  #55
muddy_ram's Avatar
muddy_ram
So I was out driving today and now my truck sounds like a train as its chuging and its bounching
Old Feb 5, 2012 | 07:04 AM
  #56
zman17's Avatar
zman17
Have you verified whether or not you have an EGR ? And have you unscrewed the the precat o2 ? I don't remember what you have and have not tried.
Old Feb 5, 2012 | 01:44 PM
  #57
muddy_ram's Avatar
muddy_ram
i cant locate the egr
Old Feb 5, 2012 | 02:05 PM
  #58
zman17's Avatar
zman17
You got a camera? Post a pic of the engine bay, specifically to the right and left of the air intake. Remove the tube going to the fender well first. And since you cant find it, you probably don't have one . Which is what I thought. But that does not explain the code you are getting.
And btw, sorry didn't mention. It should be on the passenger side back of the intake manifold. Would also have a steel tube running down to the exhaust manifold on the same side.
Old Feb 5, 2012 | 02:16 PM
  #59
muddy_ram's Avatar
muddy_ram
ok ill go get 1
Old Feb 5, 2012 | 02:40 PM
  #60
muddy_ram's Avatar
muddy_ram
