problem
Old Feb 5, 2012 | 02:43 PM
  #61
muddy_ram's Avatar
muddy_ram
1 sec gotta figer out this url thing ahah forgot my photo bucket password
Old Feb 5, 2012 | 03:05 PM
  #62
97 doesn't have EGR. You will never find it.
Old Feb 5, 2012 | 03:07 PM
  #63
zman17's Avatar
zman17
Retired Moderator - RIP
Word!....
Old Feb 5, 2012 | 04:00 PM
  #64
gdstock's Avatar
gdstock
Originally Posted by muddy_ram
Hey i was just woundering if the plenum gasket is done wouldnt the truck blow blue smoke
After all this much time, you still have the same problem. And asking for advice, yet refusing to follow it is problematic. Finding reasons not to check the plenum has taken more time than checking plenum would have taken. If plenum is blown, and cat is clogged, and O2 sensor is bad, you will get these symptoms. And the bonus prize - you may crack the head!
Part of the logic model is to check and verify things to either confirm them as the problem OR eliminate them, allowing the focus to shift to another possibility......
CARRY ON!.........
Old Feb 5, 2012 | 04:07 PM
  #65
zman17's Avatar
zman17
Could not have said it better myself. Just trying to lay low.
Old Feb 6, 2012 | 01:24 PM
  #66
muddy_ram's Avatar
muddy_ram
CARRY ON!.........
didnt i tell u guys u checked it theres no oil in there my oil hasnt gone down im more then 100% sure its not that
Old Feb 7, 2012 | 04:49 AM
  #67
muddy_ram's Avatar
muddy_ram
took my map sensor off today just woundering if it can be cleaned and how. or how to check it to see whats wrong with it or is it just 1 of those things u just replace and hope that fixes it . i cant find info on it i can only find info on the cummins map sensor
Old Feb 7, 2012 | 05:54 AM
  #68
zman17's Avatar
zman17
The Haynes manual has the test procedure for the MAP sensor. And there is really no way of cleaning it.
Old Feb 7, 2012 | 03:53 PM
  #69
muddy_ram's Avatar
muddy_ram
could the map sensor cause the problems of my truck ???
Old Feb 7, 2012 | 05:32 PM
  #70
zman17's Avatar
zman17
There not fairly inexpensive like some of the other sensors, so I for one won't tell you to replace it. Your money would be better spent getting a Haynes and testing it. But, I'd remove it and make sure the small hose behind it is not broken first. And I've seen plenty of time's a MAP code coming up, when it was actually some other vac leak or problem.
