Rear End Noise(Video/Sound included)
Most, if not all parts stores will have a Haynes. Some things in it will not be accurate for your year, as Dodge changed things over the years.Which is where also having the downloaded FSM helps. But it (the Haynes) sure does come in handy for basic repair/maintenance and a quick reference for when you need it. Both should be read before doing any procedure. This way, you know if you have the required tools and know how.
Sounds good. I am mechanically inclined as I do do my own, brakes, rotors, plugs/wires, oil changes, and recently shocks. I just want to get into some other things with my Dodge: ie- like the rear differential gasket, valve cover gaskets, possibly some exhaust work, power steering gear seal is leaking, and maybe upper and lower control arm bushings. As I seen that they were a bit wore doing the front shocks.
I will most likely buy the tools as need for the job I will be doing, which is why I want the Haynes.
I thought about printing out the FSM, but its over 2K pages! Just called AutoZone and they have one and are holding it for me.
Thanks again!
Brad
Thanks again!
Brad
Thanks again!
Brad
Thanks again!
Brad
Not that it helps if you have a rear diff failing, but, this is one of the first things you should read on here. https://dodgeforum.com/forum/2nd-gen...um-thread.html At the very least, eliminate it as a problem after you get that noise corrected.
