How to test map sensor?
Old Jan 15, 2012 | 06:22 PM
chadhager03's Avatar
chadhager03
Default How to test map sensor?
How do I test it? I've searched many forums but I can't find a definite answer. And where do I hook up the voltimeter? If there's an explanation somewhere I would appreciate a link thanks
Old Jan 15, 2012 | 06:23 PM
Easiest way to test is:
Remove from truck, leave electrical hooked up.
Hook up a vacuum source, with a gauge......
Suck some vacuum, compare what the gauge says, to the the PCM thinks. If there is too much margin, replace it.
