Can i fit 37x12.5 tires?
Please add a signature to your profile and add in your trucks details like Mutt has or like mine. That way you dont have to type it out everytime you make a post ![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
Like Mutt said, if you have the stock 3.55 gears, 37's will kill yours transmission in short order. I'm pretty sure that I saw somewhere on here that 35's are the biggest you would want to go on 3.55's. I'm sure sombody else will chime in if I am wrong.
Never heard of a 3.5" SL but ok. I don't think you'll clear the 37s with the 3" SL and 1" BL.
Are they even true 37s anyways? Meaning upon inflation they may actually be 36".
1.5" rim spacers? So where is that on backspacing amount for current wheels? That just sounds bad from a load standpoint.
I concur with the above about gearing. People want to give other critical things to consider.
On a plus note: That is a damn deal for price on the NEW set of 37". Maybe just get them and start to plan how to get them on appropriately.
Do us a favor and a measure from the ground to the top of the wheel well. Do this on level ground and use the axle as centerline. Measure for front and rear.
You might be able to get them on with minor wheel well trimming if you really want them.
I had 35" tire with only a 3" level kit and it looked like I could stuff in a 37".
Might want to get a 3" body lift from performance accessories to make the tire fit alittle better, as ive never heard of a 1" body lift, are you sure the body lift your looking at isnt just body mounts?
Trending Topics
