yet another puncture....
Old Jan 16, 2012 | 06:22 PM
chenchen's Avatar
chenchen
Default yet another puncture....
Y'all call them flats.... although it takes about a week to go flat... slow leak??
80mm acacia thorn went through exactly where the tread joins the sidewall.... real tiny hole.
I heard somewheres that sidewall holes cant be patched.
Can you fix them from the inside.
Goodly amount of tread left.... worth saving.
Chenchen.
Old Jan 16, 2012 | 06:26 PM
You could try patching it from the inside...... it would probably work.
Old Jan 16, 2012 | 07:35 PM
SilverSS's Avatar
SilverSS
A lot of places won't patch a sidewall just for liability reasons. You can do it yourself though. Just remember it when you throw a few thousand pounds in the bed
Old Jan 16, 2012 | 09:09 PM
TwistedCage's Avatar
TwistedCage
internal tire plug is only a short term fix as it makes the hole alittle bigger and if you load the truck say bye to the tire.
Old Jan 16, 2012 | 09:14 PM
dlyter09's Avatar
dlyter09
Just replace the tire. The one time I figured a plug would work the tire blew apart going down the highway. Better safe than sorry
Old Jan 16, 2012 | 09:17 PM
chadhager03's Avatar
chadhager03
Why doesn't the side wall hold a plug and the tread does? that doesn't make sense to me
Old Jan 16, 2012 | 09:24 PM
dlyter09's Avatar
dlyter09
More load bearing than the tread itself. The air is putting pressure on the sides of the tire more than the tread. That's my redneck edu-ma-cated guess
Old Jan 16, 2012 | 09:30 PM
crazzywolfie's Avatar
crazzywolfie
how old are the tire. what type of warranty on the tires. i accidentily screw up 1 tire on my truck and got a nail in the other and got them replace under warranty as road hazard but had to pay a tire tax on both them and the one that i had a nail in it cost a few extra dollars to replace because of the of how many mile i had put on it.
Old Jan 16, 2012 | 11:00 PM
kejobe's Avatar
kejobe
Rule of thumb, NO plugs or patches within 1 inch of sidewall. Thats what we were instructed when I worked in service. Auto not military.
Old Jan 17, 2012 | 05:27 PM
chenchen's Avatar
chenchen
Thanks guys..... I'll buy a new tire.
Chenchen.
