Do they make 3.73s?
Old Jan 19, 2012 | 09:58 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Coulda sworn I had seen a 3.73 for these dang things....
Old Jan 19, 2012 | 10:16 AM
tweav88's Avatar
tweav88
Originally Posted by aim4squirrels
3.21, 3.55, 3.92, 4.11, 4.56, 4.88 are the only options for the corporate 9.25" axle.
Do you mean 4.10 or is it really 4.11
Old Jan 19, 2012 | 11:46 AM
mccart's Avatar
mccart
Originally Posted by tweav88
Well actually 4.10s wouldnt hurt your mileage unless you do mainly highway driving, because if i remember correctly on another thread they were comparing speed to rpms based on the gearing, and with 4.10s at 70mph they were only about 2-300 rpms higher than the 3.55's
My dads truck as 3.92s and at 65 he runs about 2100 rpms. My truck which is exactly the same truck except mine has 3.55 gears. I run about 1750 or so at 65.
Old Jan 19, 2012 | 11:58 AM
grox's Avatar
grox
The RPM are also directly related to tire diameter. So if you increase your gear ratio by 1.104 and your tire size stays the same, your RPM would increase by a factor of 1.104 (the ratio 3.92/3.55).
So if you are now cruising at 70mph and 2000 RPM, you would be at about 2208 RPM at 70mph with the 3.92 gears.
On that same note, if you are producing 200 ft*lb of torque at 1500 RPM now, you will be producing about about 221 ft*lb of torque at 1500 RPM with the 3.92 gears.
I had the 3.92 gears put into my truck at the same time I upsized from 265/75R16s to 285/75R16s and don't recall seeing much difference. I cruise at a speedometer adjusted 70mph at almost exactly 2000 RPM now.
Old Jan 19, 2012 | 12:49 PM
mccart's Avatar
mccart
Well I've heard that with my truck being a 5 speed the 4.10s would hurt mileage more
Old Jan 19, 2012 | 01:38 PM
aim4squirrels's Avatar
aim4squirrels
There are no 3.73 gears for the 9.25 axle. Never made for that particular axle. If a truck ever came with them, Chrysler would, by law, have to at least a small inventory of them on hand for repair parts and there would at least be one aftermarket manufacturer offering them.
4.11 is the technically correct designation for Chrysler vehicles based on the 31 spline gear. 4.11 rotations of the pinion gear to one revolution of the ring gear. I only stress that for the newcomer who might only be able to find 4.11 gears in the parts catalogs, and worry that he might not be getting the correct gear set.
4.10 is a Chevy/Ford designation based on their spline count and actual gear size. And since their market share is significantly larger than the Mopar market share, 4.10 is used ubiquitously across all platforms. Even most gear vendors list them as 4.10s but you won't find that size in a corporate listing anywhere.
Old Jan 19, 2012 | 02:56 PM
Wombat Ranger's Avatar
Wombat Ranger
Also, there is really no difference. My '72 has FACTORY 4.10's out back, and FACTORY 4.11's up front. nothing to worry about. Your tires have more variance in size brand new then that.
Now that I think about it, the rear might be a 4.09.... can't remember for sure
Old Jan 20, 2012 | 01:29 PM
tweav88's Avatar
tweav88
Might be size of tire too, i run 2k rpms at about 76-77 mph according to the dash with 265 tires, and stock 3.55's.
According to my gps the speedometer is 3mph off tho, so it might actually be like 73-74
