Need help
Old Jan 19, 2012 | 01:37 PM
deathwatch789's Avatar
deathwatch789
Default Need help
Today I was driving to school and I passed someone and got to a red light when the light turned green I went and my oil pressure gauge drop to 0. I pulled over and checked my oil and it was fine so I started my truck and my oil pressure gauge went back to normal so I started driving and soon after my guage went back to 0 and my engine started making a clanking sound and it started shaking. Does anyone have a clue what this is? I drive an 01 dodge ram 1500
Old Jan 19, 2012 | 02:22 PM
dlyter09's Avatar
dlyter09
No oil pressure along with the "clanking" and shaking... might wanna start looking at new motor
Old Jan 19, 2012 | 02:44 PM
Wombat Ranger's Avatar
Wombat Ranger
^^^ what he said. It sucks, but If it's making those noises it's been run with insufficient oil pressure for too long.
Old Jan 19, 2012 | 03:20 PM
UnregisteredUser's Avatar
UnregisteredUser
Death rattle.
Old Jan 19, 2012 | 06:27 PM
Ramzy's Avatar
Ramzy
Bad as it sounds. Stick a fork in it, it's done.
Old Jan 19, 2012 | 07:53 PM
mstephen89's Avatar
mstephen89
its not totally done yet...you could do a low budget rebuild now, if you keep running it and throw a rod or something, then you'll be looking for a new motor
Old Jan 19, 2012 | 08:01 PM
dhvaughan's Avatar
dhvaughan
i'd drop the oil pan and have a look. could be a sludged up oil pump screen. especially if it swings back and forth between normal - 0 - normal - 0.
if no obvious rod, bearing, or piston problems - replace oil pump with melling high volume pump, clean the screen and tube, and see if that helps. don't forget to prime the pump.
http://www.pavementsucks.com/tech-article-31.html
