Best Way to Clean Engine Bay
Old Jan 22, 2012 | 12:39 PM
Nereaga's Avatar
Nereaga
Default Best Way to Clean Engine Bay
OK to say my engine bay is dusty/dirty is a monumental understatement! It is down right ugly in there. Anyone done this recently? What did you cover? What should I definitely stay away from spraying with water or engine de-greaser?
I am smart enough to stay away from the distributor/wires/intake with water. Should I cover things up with plastic or bags? I have a whole roll of plastic laying around.
Any tips would be greatly appreciated! I don't really want to post a pic, just out of being embarrassed with it... lol but I sure can if you wanna poke fun of me today....
TIA
Brad
Old Jan 22, 2012 | 02:00 PM
dhvaughan's Avatar
dhvaughan
i spray anything and everything with walmart engine degreaser, let soak, then spray off. i don't cover anything or worry about it. i did have the tps get wet once and surge at idle, but it dried out after a little while. but i do spray water at lower pressure and maintain some distance as just a rinse and not a "pressure wash".
simple green works well. so does 409.
brake cleaner works well on heavy deposits on metal - but go easy on plastics, wires, rubber, gaskets, paints. the walmart brake cleaner is very harsh and will melt some softer plastics.
Old Jan 22, 2012 | 02:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You are in PA. Id wait for spring if I were you.
Old Jan 22, 2012 | 02:32 PM
Buried Alive's Avatar
Buried Alive
^ +1 wait till spring unless you can do it inside somewhere heated and leave it in there till it dries.
Old Jan 22, 2012 | 02:43 PM
merc225hp's Avatar
merc225hp
I wash my motor once a week in the winter at the car wash it does not hurt a thing. So wash it. Dhv has it right.
Old Jan 22, 2012 | 07:00 PM
Nereaga's Avatar
Nereaga
Well tomorrow is supposed to be 50F so I will be going tomorrow and cleaning the engine bay. Should I turn the truck off or keep it running? Does it matter?
Thanks guys!
Brad
Old Jan 22, 2012 | 07:11 PM
stewie01's Avatar
stewie01
Turn it off, save some gas! Really shouldn't matter though.
Old Jan 22, 2012 | 07:24 PM
BangMx's Avatar
BangMx
Id disconnect the battery also
Old Jan 22, 2012 | 07:43 PM
merc225hp's Avatar
merc225hp
Shut it off, no need to disconnect the batt.
Nereaga's Avatar
Nereaga
Good to know! Thanks guys!
