power steering
Old Jan 24, 2012 | 04:50 PM
leahyhfarms's Avatar
leahyhfarms
Default power steering
Heres my problem. My steering is gone very heavy at idle and if I rev the motor it will get easier to turn. Its not low on psf and it was never ran low on fluid. It all started a few weeks back when I nearly ran down two dam fools who were out walking their dam dog in the dark ( no light, no vis coat, and walking on the wrong side of the road). I had to make a very severe turn to advoid hitting them and it was a few days later than I noticed the steering was a little heavy. Somethimes its perfect and today its was almost like I had no ps. Did I blow out seals in the ps pump or box or what do you guys think.
Old Jan 24, 2012 | 04:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you checked the belt to make sure it is not slipping? Another thing to look at is the belt tensioner.
Old Jan 24, 2012 | 05:10 PM
leahyhfarms
I did check the belt and tensioner and they are perfect.
Old Jan 24, 2012 | 06:28 PM
More likely the pump than the box...... If you have a bunch of miles on the truck, sure wouldn't hurt to just replace the pump.
Old Jan 25, 2012 | 12:01 AM
Ramcountryboy's Avatar
Ramcountryboy
I had intermittent heavy steering for a while maybe a month or so, then one day, boom, my seal blew between the pulley and the pump, psf everywhere, not to mention no power steering. Picked a different one up at the jy for $35 and so far so good.
Old Jan 25, 2012 | 08:22 AM
Hans_GZP's Avatar
Hans_GZP
Be careful with the reman'd ps pumps. I tried one and ended up with the same issue you are describing. I went with a new pump from PSC and couldn't be happier.
