Thoughts on multi-port injectors.
Just throwing this out there so see what your guys thoughts or opinions are on multi-port vs single port injectors. Are they worth the extra money. Do they really give you up to another mpg. I just ordered the Hughes plenum kit and figured id do the injectors as long as i was in there. any feedback or better brand of injector would be greatly appreciated.
thanks
B
thanks
B
I always thought multiport injection meant theres an injector for each port vs throttle body injection where thers one or two injectors spraying into the throttle body like many 80's chevy trucks and my 84 vette...
Me too.
The best thing you can do for mpg besides making sure everything works in your drivetrain properly is either pull the lift kit and go back to stock tire size or install 4.10 gears to match your 33's especially if you have 3.55 gears now. (3.92 isnt so bad with 33's) mismatched gears are the biggest contributor to poor gas mileage you could possible do... Its expensive to change the gears to match tires but its the only way to reduce the load on the engine and tranny back to stock levels and increase the power transfered to the ground, reducing the amount of wasted fuel you would be consuming without them...
Changing to a different brand of injectors isnt going to do anything... only if you had a better flowing built up engine to utilize bigger injectors.... You would still get better results from the gears.
yeah the truck is running completely stock all around right now getting 7-8 mpg which is half of what i should be getting. so im just trying to dot all my t's and cross my I's. lol to get the milage back up to where its supposed to be before i dive into upgrading the engine, suspension, lift, and gears. its one thing to get that milage when the truck is all modded out but stock esp with alot of hwy driving is just unacceptable. so ill stick with the OEM injectors. thanks guys.
And you already have multiport injection...all dodge ram magnum engines have it...I explained the difference above.
I think he is more referring to the number of holes in the injectors, that actually spray fuel. Stockers only have one. Others have more..... The idea behind our single hole injectors is, it shoots the stream right at the back side of the toasty warm intake valve. The heat vaporizes the fuel, and puts it into a state that will actually burn. I don't know if multi hole injectors are really that much of an 'upgrade' on our trucks.....
