Nv3500 and 360
Old Aug 31, 2022 | 05:07 PM
NV3500 never came from the factory behind a 5.9. They did behind a 5.2, and rumor has it, the bellhousing bolt pattern is very close. On bolt (at the very top) doesn't line up, I think.
That said, if the trans really was behind a 5.9..... I wouldn't expect it to last very long.
Old Sep 3, 2022 | 07:07 PM
merc225hp's Avatar
merc225hp
Default Ideal f no but it can be done .
Two years on a nv3500 with 40x15.50r20 tires , 4.10 gears and a 5.9.
Old Sep 4, 2022 | 11:45 AM
Hey Merc! Long time no see!
Welcome back.
Old Nov 13, 2024 | 07:59 PM
Iandakbender's Avatar
Iandakbender
Default Nv3500 clutch and 5.9 flywheel
Are the 6 bolts for the pressure plate the same on a 5.9 flywheel as the 3.9? what clutch and flywheel combo do I need to order to run my 3500 behind my 5.9l?
Old Nov 13, 2024 | 09:03 PM
You need a flywheel for the 5.9, it is externally balanced, the other motors are internally balanced, and are NOT interchangeable. Get a new clutch and p-plate for the 5.9 as well, trans spline count didn't change with engine side. That way, you can be sure everything fits.
Old Nov 14, 2024 | 06:22 PM
Los_Control's Avatar
Los_Control
I have the NV3500 behind a Chevrolet 350. The truck has over 400K miles on it and unknown previous history. Motor replaced and rear end rebuilt .... no idea on the transmission but it works great.
Old Dec 18, 2025 | 10:45 AM
noremactrawets's Avatar
noremactrawets
Some 2500s came factory with 5.9 and nv3500
Old Dec 18, 2025 | 01:44 PM
Erm, no, they didn't..... Maybe the light duty 2500s, which were basically a slightly beefed up 1500..... but in all my years here, I haven't seen one.
