Maybe some advice would be wise before I do this...
Old Jan 26, 2012 | 06:50 PM
drewactual's Avatar
drewactual
Default Maybe some advice would be wise before I do this...
Howdy...
I have a '02 cali emissions 5.9L... it 'had' three cats OE.. one on each back just south of the collector, and one great big ol' fat thing.. It now has four.. the same two just behind the collectors(one each), and two magnaflow high flow's.. I run them into a magnaflow tru-x muffler, and now have dual X exhaust..
I have an exhaust leak that has finally pushed me over the edge.. I have a set of remflex gaskets, and stage-8 header bolts staged to install.. I also have header wrap, and sealer- along with some high temperature paint (to touch up, but enough for a whole new coat)..
I live on the coast of NC, which is laterally, as far as you can get from Cali and still be in the US and dry.. There are no emissions tests here.. But, there is a visual test..
Is it worth it to punch out those pre-cats? They are OE, and have 165k miles on them.. I fixed the plenum gasket at around 145, and suspect they are at least a little tired.. This would be the perfect opportunity to do so, because I hope to not have to mess with exhaust for a good while after this... Has anyone here had a rig with the pre-cats and removed them?
Old Jan 26, 2012 | 06:56 PM
Ramcountryboy's Avatar
Ramcountryboy
Well I'd gutt/remove them but thats just me, then again I don't have emission testing at all here... but i still would if we did. But again, thats just me
Old Jan 26, 2012 | 07:25 PM
BackwoodsRam's Avatar
BackwoodsRam
Do it
Old Jan 26, 2012 | 07:57 PM
Thirded. Gut them fellers.
Old Jan 26, 2012 | 08:59 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I would be worried about setting a code, being a Cali truck and all.
Old Jan 26, 2012 | 09:01 PM
BackwoodsRam
Cali rigs set a code if you fart in them
Old Jan 26, 2012 | 09:04 PM
dodge dude94
EXACTLY!
That is what I am talking about.
Old Jan 26, 2012 | 09:27 PM
drewactual's Avatar
drewactual
the codes are manageable, I'm willing to bet.. I've played with o2 sensors for a while now, and think I can manipulate them to believe whatever I want them to believe..
the sensor isn't so smart.. it simply sniffs air inside the tube, as well as outside.. the bulging part has a protected strand of a special type of conductive material that registers difference in present o2 in voltage.. it sends that voltage to mr. PCM.. Mr. PCM determines if those volts are in a suitable parameter..
the upwind sensor is crucial, but it won't really be messed with during the field dressing..
the downwind sensor is absolutely in play for fuel trim, BUT, it isn't as important as the upwind.. from what I've researched, the PCM takes the voltage difference from the upwind and uses it to trim fuel.. then the downwind voltages are pushed through a formula to fine tune the trim with what is going on upwind..
VERY loose example not using ANYTHING close to real data:
upwind: .3 volts between inside and outside..
Mr. PCM: we're lean, add fuel..
downwind: .02 between inside and outside..
Mr. PCM: I know that upwind sees .3vdc, and downwind sees .02vdc, and I know that a properly functioning catalyst should shave somewhere around 40% off of it, so the cat is doing it's job~ however, bumping the fuel .1% will increase the upwind reading, and keep the downwind within parameters as well.. I'm giving it a shot and seeing what happens.. because I can.. I'm Mr. Mysterious Master of the floggin' truck..
con't...
anyway, you can manipulate the downwind sensor from inside the stream or from outside.. the inside is pretty easy (non-fouler), the outside is a little tougher (reducing the flow by partially blocking the ports).. I'll figure it out if a code pops up.. those things themselves aren't too smart.. Mr. PCM is.. but he can only make decisions based on the information presented, dig it?
I think I'm going to do it.. I've only heard one voice of dissension over the several forums I've asked this in..
Old Jan 26, 2012 | 09:34 PM
BackwoodsRam
con't...
I like that, sounds like my rigs PCM
Old Jan 26, 2012 | 10:37 PM
gdstock's Avatar
gdstock
con't...
Go for it! I am sure you can figger a way to outsmart Mr. PCM. Although I don't have a cali rig or emission testing here, I will be interested in the results.
