Wheel bearings
Old Jan 29, 2012 | 07:27 AM
zman17's Avatar
zman17
Retired Moderator - RIP
In 2000 Dodge used the same style sealed hub unit as a 4x4 on the 2wd's .
Old Jan 29, 2012 | 11:32 AM
offroadjosh's Avatar
offroadjosh
Side note. when you bolt that puppy back up, use anti seize on the hub surface! makes it 10times easier taking it off next time.
Old Jan 29, 2012 | 01:33 PM
zman17's Avatar
zman17
Although the 2wd uses the same style (sealed hub unit) it does not bolt on through the back like our 4wd's do.
On a side note, some one recently replaced just the bearings on a 2wd sealed hub. Maybe a search is in order.
Old Jan 29, 2012 | 01:36 PM
zman17's Avatar
zman17
OK, so I did the search,LOL. https://dodgeforum.com/forum/2nd-gen...-bearings.html
Old Jan 29, 2012 | 03:05 PM
KxRideRon125's Avatar
KxRideRon125
so if timkin isn't that great anymore... what brand do you recommend
Old Jan 29, 2012 | 03:23 PM
gdstock's Avatar
gdstock
I have always had excelent results with SKF bearings.
Old Jan 31, 2012 | 04:36 PM
KxRideRon125
it doesnt have any wires going to the front brakes
Old Jan 31, 2012 | 06:48 PM
zman17's Avatar
zman17
So you don't have front ABS that's all. I'd go BCA as a second choice to Timken. Federal Mogul is the maker and they are still putting out some pretty good parts, except MOOG may be taking a hit in quality. They also put out the National line.
