Wheel bearings
Old Jan 28, 2012 | 04:00 PM
KxRideRon125's Avatar
KxRideRon125
Default Wheel bearings
passenger wheel bearings are goin bad and im about to change them...can i use the same hub or should i buy a new one...i planned on just repacking the bearings
Old Jan 28, 2012 | 04:16 PM
BackwoodsRam's Avatar
BackwoodsRam
These trucks have unit bearings, you can't repack them. You have to by a whole hub assembly
Old Jan 28, 2012 | 04:50 PM
offroadjosh's Avatar
offroadjosh
auto parts place has timkins for 72 bucks a pop..
Old Jan 28, 2012 | 04:53 PM
KxRideRon125
how do i tell if it has 4wd abs or 2wd abs or if it has them at all im pretty sure it has then just done know weather its 4 or 2
Old Jan 28, 2012 | 05:31 PM
offroadjosh
see wires coming off front hub?
Old Jan 28, 2012 | 08:24 PM
mstephen89's Avatar
mstephen89
is your truck 4x4 or 4x2, if it's 4x2 you can buy just the bearings.
Old Jan 28, 2012 | 09:27 PM
Augiedoggy's Avatar
Augiedoggy
Timkin was added to the list of companies that were bought out in the last couple years by a bigger bearing company........ They are now made by another manufacturer overseas and aren't all that good anymore.... The performance shop that redid my rear diff told me they no longer use them in the racecars because they dont hold up well anymore...
Old Jan 28, 2012 | 09:32 PM
gdstock's Avatar
gdstock
Get a build sheet from Dodge. Tells you everything.
Old Jan 28, 2012 | 10:09 PM
Including things we DON'T have..... Like Power Rack and Pinion steering.
Old Jan 29, 2012 | 12:54 AM
silverbullet-dodgeram's Avatar
+1 i was gonna say the same thing
