Idle issue?/almost dies
With lights dimming as it trying to die, I suspect something else is the problem.
When the TB was cleaned, did you do it or someone else? Was IAC removed and cleaned at that time, and how long ago was that done? Has it been running right since then until now?
If IAC pintle was turned or pushied in or out, it would have been damaged and needs repplaced. I suspect with the lights dimming issue, there is a bad or loose ground. Check negative cable at both ends. make sure cable isn't breaking down at connector under insulation. Clean connection at both ends.
