looking at a new timing Chan for the dodge
Old Jan 29, 2012 | 12:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by xjarhead69
Download service manual. It will walk you thru it.
Dave
+1000. Get a Haynes also. And read about the procedure before you attempt to do the work.
Old Jan 29, 2012 | 01:46 PM
gdstock's Avatar
gdstock
Mine had almost 3/4" slop in it at 134000 miles.
Old Jan 29, 2012 | 04:03 PM
lowenasty 08's Avatar
lowenasty 08
How would u line the marks up so the timing is not off....
Old Jan 29, 2012 | 04:21 PM
gdstock's Avatar
gdstock
Look at FSM....remove cover - look at FSM - put socket on crank bolt......look at FSM.....turn bolt to line up timing marks of sprockets....Mya have to turn more than one rev.
Then you can pull sprockets and chain. DO NOT move crank or cam...
Old Jan 29, 2012 | 05:09 PM
Then you can pull sprockets and chain. DO NOT move crank or cam... while the timing chain and gears are off.
added a bit there...... just for clarity.
Old Jan 30, 2012 | 07:26 AM
kd5taa's Avatar
kd5taa
Its not too bad, I just did it yesterday. It probably took me 6 or 7 hours. I had some trouble getting the fan clutch removed and crank pulley/harmonic balancer off (its a one piece on my truck) but those were the only hitches. I haven't started it yet, I still need to change the oil. Hopefully I did it right!!
Old Jan 30, 2012 | 07:33 AM
kejobe's Avatar
kejobe
Originally Posted by Augiedoggy
FYI you can hit the little edit button in the corner of you posts to correct something you mistyped instead of posting another post...
FYI, on mobile version there is no edit button, only quote. I dont know if he posted from mobile or not though.
Old Jan 30, 2012 | 08:31 AM
Augiedoggy's Avatar
Augiedoggy
good point... with all the text slang he was using it probably was from a phone..but you cant tell these days...The younger generation has a real problem using english when writing... I hear about it all the time from an English teacher friend...
Old Jan 30, 2012 | 09:20 AM
lowenasty 08
I am on my phone...
Old Jan 30, 2012 | 10:52 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Using a phone to communicate surely is not an excuse for misspelling and grammar is it? No, I'm not saying you're stating that. I agree with you.
Originally Posted by lowenasty 08
I am on my phone...
Curious how many times the OP counted the times -- FSM appeared in the thread already?
Mopar has a double roller timing chain.
