rear driveshaft u joints
Old Jan 30, 2012 | 04:54 PM
grupar14's Avatar
grupar14
Default rear driveshaft u joints
Replacing both of my u-joints on my rear drive shaft , what should i replace them with?
Old Jan 30, 2012 | 06:25 PM
dodgeboy1979's Avatar
dodgeboy1979
precision makes a good u-joint, just make sure the new ones have grease fittings so you can grease them yourself.
Old Jan 30, 2012 | 07:27 PM
bekins01ram's Avatar
bekins01ram
+1 on the precision u-joints. And take it from me, if you buy the greasable ones (like i did the first time) you have to actually grease them from time to time. Mine lasted a year and a half without ever greasing them. Oops. Not a fun chore to have to do again in such a short time. Those little needle bearings in there turn into dust, without grease, and it makes some pretty crappy noises. LOL. Lesson learned. Grease the u-joints at every oil change, is what i was told.
Old Jan 30, 2012 | 08:35 PM
grupar14's Avatar
grupar14
i got spicer for the front u joint (that connects the slip yoke to the driveshaft) and precision for the rear. Had to go with spicer on the front because the precision one i had, the cap broke will putting it in .
