dodge clunk
Old Feb 10, 2012 | 10:47 PM
laharve5's Avatar
laharve5
Ball joints were recently replaced. When I push on the shock, I can feel clunking sound when holding upper mount.
Old Feb 10, 2012 | 11:18 PM
gdstock's Avatar
gdstock
Use two wrenches and tighten the crap out of them!
Old Feb 11, 2012 | 01:56 PM
laharve5's Avatar
laharve5
That's what I gotta do thanks. Any ideas for belt noise? Belt was replaced last year. Its only noisy in the winter. I was putting some type of spray on it that took away noise last winter. I forget
what it was though.
Old Feb 11, 2012 | 03:53 PM
gdstock's Avatar
gdstock
You may want to check to see how many ribs are on the belt...and how many grooves on belt. I have read that others had differences that caused problems. Then check all pulley algnment and make sure they are all properly aligneded. A small misalignment will cause problems. Also check tensioner to make sure there is no wobble in it from a worn bearing.
Old Feb 11, 2012 | 07:49 PM
dhvaughan's Avatar
dhvaughan
what it was though.
what kind of noise? squeaks or clicking?
the best first step is to rotate the tensioner over toward the center of the motor and release the belt. then rotate and twist each pulley by hand checking for smooth and quiet rotation and zero twist. tensioner pulley or idler pulley is easily replaceable. check rockauto and amazon for best price.
for the belt - get the more expensive premium belt from goodyear or dayco. don't get the cheap one.
if tensioner is not holding it real tight, replace the tensioner assy.
Old Feb 11, 2012 | 07:54 PM
redneck_ram's Avatar
redneck_ram
my fiances jeep grand cherokee has the same clunk, im thinking its the track bar on hers... not a bad place to looik on your truck. i was suprised to see a SFA under the jeep when we bought it. good ole dana 30!
Old Feb 12, 2012 | 12:46 AM
Wombat Ranger's Avatar
Wombat Ranger
^^ZJ or WJ? Just curious...
Old Feb 12, 2012 | 07:06 AM
redneck_ram
its a zj. last year of the zj too. its the i6 with the 42re. 244k on the clock. not a whole lot of rust, but i did find some. wasnt a bad price for it at 1400.
Old Feb 14, 2012 | 03:04 PM
laharve5's Avatar
laharve5
I finally got the chance to tighten with wrench, one full turn. No more thumping sound. Thank you!
