cat removal problems?
Old Jan 31, 2012 | 03:17 AM
Kierbo77's Avatar
Kierbo77
Default cat removal problems?
Hi I have a 1998 dodge ram 1500 sport 5.9L 4x4 automatic and I really want to remove my cat just to make it louder and I don't want to do it if its gonna mess up my gas or back pressure? Now I dont know if it will or not? This is what I need help on. I know opinions go either way but I really just wanna cut it off and put a pipe in it's place. Tell me if it could benefit or help me. Or if I do, do this what cheap improvements I can do to make it run like a champ after removal. Please stay on subject, thank you.
Old Jan 31, 2012 | 05:15 AM
97tn4x4's Avatar
97tn4x4
You can get a offroad y pipe from jegs to go in its place and it'll actually help you out a bit as long as you don't have to worry about inspections. There's a list of stuff you can do after just depends on how deep your wallet is.
Old Jan 31, 2012 | 08:38 AM
Augiedoggy's Avatar
Augiedoggy
you can go with a high flow cat... they are louder...I had a gutted cat I just replaced with a magnaflow and the sound difference is almost unnoticable... if you want the mean sound get headers..they can be had for almost the same cost as a new cat.
Old Jan 31, 2012 | 10:59 AM
Kierbo77's Avatar
Kierbo77
So what bad things will happen or what good things will happen if I just replace it with a pipe? I'm going the cheap way. Already cut the muffler and put a pipe in it's place. I just need to know the exact problems I might have? Backpressure and gas are ones I hear of. But most people say it hasn't happened to them when they cut their cat out.
Old Jan 31, 2012 | 11:22 AM
gertie240's Avatar
gertie240
mileage, always going to run rich, and maybe a cel because of the o2
Old Jan 31, 2012 | 11:44 AM
Bad? Nothing really. Maybe a rear O2 code if you don't do the non-fouler trick. (DIY in faq section.) Not exactly emissions legal.....
Good? Better flowing exhaust equals better breathing for the engine equals a bit more power. Especially if the cat is partially clogged.
Old Jan 31, 2012 | 12:12 PM
Kierbo77's Avatar
Kierbo77
So what if I cut it out? Leave the o2 sensors in the pipe?
Old Jan 31, 2012 | 01:10 PM
Put the non-foulers on the rear O2. Will work fine.
Old Jan 31, 2012 | 02:46 PM
Kierbo77's Avatar
Kierbo77
whats a non fouler and where can i get one?
Old Feb 2, 2012 | 06:11 PM
gertie240's Avatar
gertie240
I think they mean to use a spark plug non fouler on the o2 . most auto parts stores have them.
