Plenum Done, Now No Start...
Old Feb 12, 2012 | 10:42 AM
  #41
Stankp's Avatar
Stankp
Again, long delay in posts... Put new timing gears and chain in. I did not go with the pricey stuff, just went to NAPA. All went together quite well. Go to start her up and all I get is a lot of cranking.. I then proceed to again check for cam rotation by inspecting the rotor and we have rotation. I then checked for spark at the coil and the plug and yes have spark in both locations. Next check for pressure in the fuel rail and again I have fuel. So any again I come to you my fellow owners for any thoughts or suggestions... I have checked, re-checked and checked once more all connections and all are sound. Am I missing something obvious??
Old Feb 12, 2012 | 10:59 AM
  #42
Got compression?
Old Feb 12, 2012 | 11:07 AM
  #43
Stankp's Avatar
Stankp
I guess that is the next step.. When cranking over by hand (ratchet) there is definitely resistance on the strokes..
Old Feb 12, 2012 | 12:12 PM
  #44
gdstock's Avatar
gdstock
Are you getting a pulse at injectors?
Old Feb 12, 2012 | 01:36 PM
  #45
Stankp's Avatar
Stankp
Mmm, have not checked for a pulse at the injector. I will poke around and see how to check that..
Old Feb 12, 2012 | 01:53 PM
  #46
merc225hp's Avatar
merc225hp
Comp test is first and foremost at this time, nothing else matters until that is done.
Old Mar 1, 2012 | 05:44 PM
  #47
Stankp's Avatar
Stankp
Sorry for the long delay in updates, been traveling a bit. I thought I would give everyone the update of how it all shook out. I went through a number of things, checking injectors, coil, dist., etc. Was coming up with nothing. Again, turning over by hand felt as though there was some compression, but gave the test a go anyway. Drum roll please..., no compression, valves crashed...
Turns out this engine is an interference type design. If your timing chain or gear fails you will bend valves... Learning this just about brought me over the edge (a can of gas and a lit match were in hand). Knowing that I was going to be traveling I towed the truck to a local engine shop (great guys) and they pulled the heads. There were all the typical things from a truck with 170k, cracks, etc. plus bent valves, push rods, etc. from the timing gear fail. So they went in repaired one of the heads and put a new one on the worse side. I have all new valves, rockers, push rods, etc. They put it all back together and I picked the truck up yesterday. Drives great, will check oil consumption and check milage this weekend.
Thanks for all the insight guys, this has been an extremely expensive but interesting learning experience. I have to say, I do miss my old Cummins more than ever...
