governor pressure solenoid/battery gauge drop
Old Feb 5, 2012 | 07:47 PM
stewie01's Avatar
stewie01
Stolen from another thread on DF,
P0753 Shift Solenoid A Electrical
P1765 (M) Trans 12 Volt Supply Relay CTRL Circuit An open or shorted condition is detected in the Transmission Relay control circuit. This relay supplies power to the TCC.
https://dodgeforum.com/forum/1st-gen...and-p0753.html
P1495 Leak Detection Pump Solenoid Circuit
Old Feb 6, 2012 | 08:59 AM
chelios1368's Avatar
chelios1368
Thank you stewie01 im gonna go through checkin the connectors before I get into the tranny. I've been searching all of the forums haha
Old Feb 6, 2012 | 05:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure you don't have a situation like this. That's the main harness plug to the tranny.
Old Feb 7, 2012 | 03:06 AM
chelios1368
just picked up a volt meter today so i can test the connections and so forth. the biggest mystery to me still is my battery issue. like i said when i start my truck the volt gauge (in the truck) is saying about 11 volts which is a little lower than normal. it will stay there until i actually start driving. ive replaced the alt. twice,new battery,new pcm. could the codes im getting from the tranny be causing this. the truck wont die unless i drive it for aboout 5 miles. and even after the battery gauge first drops to nothing i can shut off my truck and restart it with no issue....until i start driving. im still gonna try another battery but im just curious to know if anybody has had these problems at the same time. both my issues started at the same exact time.
Old Feb 7, 2012 | 09:24 AM
gdstock's Avatar
gdstock
Sounds like something is triggering the ASD. May hook voltmeter to ASD and drive and see if it is shutting off.
Old Feb 7, 2012 | 06:06 PM
chelios1368
what is the ASD?
Old Feb 7, 2012 | 06:12 PM
zman17's Avatar
zman17
Automatic Shutdown Relay =ASD . It's located under the PDC cover next to the battery.
Old May 30, 2012 | 04:12 AM
flyboydale54's Avatar
flyboydale54
When shopping for a PCM, I look not at the price as the determining factor of where to purchase it. Ones to stay away from are the companies that show up on "Rip-Off.com". You will see there are many reports of a so-called cheap company to get PCM's from. They rebuild with sub-standard components and many are faulty from this company on arrival. They have no support and do not honor their low time warranty. Stay away from this company. A company that will talk to you in great detail on the phone and gives you a lifetime warranty providing you return the core to them with 2 weeks can be found at... (allcomputerresources.com)
Old May 30, 2012 | 04:33 AM
flyboydale54
allcomputerresources.com has a good supply of well remanufactured PCM's and TCM's. They carry a lifetime warranty, which says a lot these days. They will disguss problems on the phone with you. It is possible that your PCM is defective. Also, your TCM can be damaged by a faulty PCM. If something got shorted in the PCM, then that can ruin or damage your TCM too. Since the supply voltages come from the PCM for your TCM, one can cause problems with the other. Most major auto parts stores can test your alternator if you take it off and take it in to them, or drive the truck there and they will test it on your vehicle. 11 volts is way too low whether the vehicle is running or not running. If you charge your battery, the voltage should be near 13 volts fresh off the charger and I have seen slightly above 13 volts immediately after an overnight charge at lower amp settings. With the vehicle running, you should see between 13.8 to 14.3 volts as a normal range. If you crank it a lot to get it started you may even see up to 15 volts until the battery level charges a little bit. However it should not stay up at 15 volts for very long before dropping back to the normal range above. I eliminated my alternator as a possible problem by removing it off the Dodge Caravan and having AutoZone test it for me. If voltages are low, it can cause shifting problems also. Welcome to the wonderful world of electronic controlled everything in vehicles today with that OBDII or OBDIII Systems.
Old May 30, 2012 | 06:56 AM
chelios1368
Sorry for not up dating my findings....it ended up being the #24 pin on my pcm....controling the alt. And tranny....just bypassed the wire into a another wire that only gets power when the key is on...cant remember which one but as long as its a remote line like that itll work.
