pcm change
Old Feb 1, 2012 | 12:17 PM
minitrucker's Avatar
minitrucker
Default pcm change
I put a cheap aftermarket coil in my truck and it fried my pcm..so the mechanic says... I changed pcms after putting a new crank senson and stock replacement coil.. Now it has spark but no injector flash...starts when pouring gas down the tb...injectors will work when the mechanic tries with his dianostic machine....is there a vin lockout or could the pcm have a security feature?
Old Feb 1, 2012 | 12:19 PM
minitrucker
And the truck is a 01 ram 4x4 5.2..... Im having difficulty finding a replacement pcm aswell
Old Feb 1, 2012 | 03:12 PM
merc225hp's Avatar
merc225hp
I am also having a hard time finding a jtec (pcm) for your 5.2.
Can you please post your org jtec numbers so I can cross-reference them.
Found it Jtec part # 56040269AB super seeded by this new number 56040269AG $700 @ the dealer.
Old Feb 1, 2012 | 05:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You sure ALL the ground wires are clean and connected? Check the 2 near the power steering pump. There is one large and one small one.
Old Feb 1, 2012 | 08:57 PM
minitrucker
Every ground is clean and checked
Old Feb 1, 2012 | 09:38 PM
pcfixerpro's Avatar
pcfixerpro
You are correct. Mine is the same part number you found... but mine was a lot cheaper by going with a reman pcm from cardone. I got mine at a local store, but looks like rockauto will ship a cardone reman to canada.
If you really need a computer, 790269V is the part number you want. Look up rockauto.com
Wish you luck!
