Trans Question
Old Feb 3, 2012 | 10:55 AM
gdstock's Avatar
gdstock
Originally Posted by NewbieDodge
Update: A code finally showed
forgot# but- Governor Pressure Sensor Voltage To High or To Low
Went to local parts store and no Sensor?
Picked up a bottle of +4 to see if the fluid level is causing the problem.. have not put in yet but I will post results!
Before adding fluid, check level in Neutral. Check electricla connector on driver side of transmission case near shifter. Make sure connector is tight and there are no loose wires or skinned insulation. If fluid is low, now would be a good time to drop the pan, check and clean the governor solenoid and pressure sensor and check to make sure these connectors are secure. Install drain plug on pan before reinstalling (makes it easier next time) and refill with ATF+4.
Old Feb 3, 2012 | 03:26 PM
NewbieDodge's Avatar
NewbieDodge
will do!
