5 inch coil spring and block lift help?
Old Feb 5, 2012 | 05:30 PM
  #21
merc225hp's Avatar
merc225hp
It all depends on the kit on what parts are included. I just want to see you have a SAFE truck and as complete and ez install as possable.
Old Feb 5, 2012 | 05:35 PM
  #22
ryan0714's Avatar
ryan0714
yea man, work smarter not harder, ok so 6" drops on everything, but do you know where to get the brake lines i need? all i could find was 4"...
and are we triple sure on the drops? i mean i went and looked and like the pitman arm dont seem to be in any kind of bind with that spacer in there right now, so if i add 3" more are you sure i need the 6" and not just the added 3" im puttin...
it all works a-ok right now so i lift it 3" more i should use the 3" drops... and then those 4" brake lines would work.
Old Feb 5, 2012 | 05:52 PM
  #23
merc225hp's Avatar
merc225hp
Here you go, make sure you are sitting down when you look at the prices. http://www.egrbrakes.com/index-main.htm I guarantee you need the drop pitman arm, funny thing is all it does is move the draglink from the top to the bottom of the pitmanarm.
Old Feb 5, 2012 | 06:55 PM
  #24
ryan0714's Avatar
ryan0714
yea i know i am gonna need it. just sayin if its workin right right now, and i add 3 " more then i should only need the 3" drop ones right? i dont wanna drop it to much.... and thanks for the brake lines link.
Old Feb 5, 2012 | 07:14 PM
  #25
merc225hp's Avatar
merc225hp
Go with this http://www.topguncustomz.com/Store/G...view=261131806 or this one
http://www.topguncustomz.com/Store/G...view=250578035 They both fall within your lift range.
Old Feb 5, 2012 | 08:35 PM
  #26
ryan0714's Avatar
ryan0714
yea rgr that. i was being so brain dead i guess from the fumes of paint earlier, i realize now that i need the 6" drop ones. so here i smy grocery list so you have an idea of what ima end up with.
-3" body
-3" level kit
-3" suspenion
--6" drop pitman,track,sway link, control arms
-Dual Steering stabilizers
-35s
-Fox racing shocks with reservior
